CH Pump / 3 port diverter valve
6 Mar 2003
When heating is turned on lots of buzzing coming from diverter valve ( this is a grey square box, Siemens, fitted close to the pump ) and heating takes between 30mins and an hour to fire up.
Is the problem likely to be with the diverter valve or the pump ??? and any solutions ??
Thanks in anticipation..
I am not a plumber or heating engineer but i would say the buzzing is the motor that operates the valve. Does it have a "manual" lever? try moving that if that solves the problem with your system the valve has gone. you can get a new one from here
