Hi all,
I've recently relocated my CH pump. It's all working fine. However when I bled the pump I noticed that the sealing washer on the bleed screw was past it's best. It's now leaking!
Anyone know what size washer it is?
Do I want a fibre washer or a copper one? The old one was fibre.
I plan on replacing it with the aid of an assistant's thumb to block the hole whilst I swap the washers over - Got to be easier than draining down so long as the heating has been off all day.
Photo of the pump is here:
View media item 17868
It's a Euramo Gold. Class F if that helps.
All help appreciated.
Ant
Ant
