Hi - I have looked through your forum and can't find what I need to ask, but apologies if this has already been posted elsewhere.
I wish to install a multifuel boiler (possily a charnwood Cove 2B) in a ground floor flat. I obviously have no loft space and a maximum ceiling height of 2400mm.
I wish to run underfloor heating in the bulk of the flat (kitchen/diner, utility, Bathroom, small bedroom and hall), all on solid floors prepared ready to accept UFH, and radiators in the remaining rooms - master bedroom and lounge (suspended floors) bedroom 2 and porch (solid floors)
I have one main bathroom with bath and shower mixer and one en-suite with thermostatic shower and would like mains pressure hot water.
I have a potterton promax combi HE (24kw) which I only wish to use as back up, and not as the main source of heat.
I would like the facility to add solar water heating into the system in the future.
I was led to believe that as long as I had a large heat leak radiator from the multifuel boiler and if I fed the multifuel boiler (and the gas boiler) into a thermal heat store with an F & E tank above the store, I would be able to run the above system all on one floor level.
I have now been told the thermal store must be located above the boiler(?) and an F & E tank above that. Obviously, this is not possible.
Can anybody please advise?
Many thanks
Many thanks
