Changing a gear knob
15 Jul 2005
Happy New year all
Just a quick question pls. I have a '01 Citroen C5 with a knackered gear knob.....anyone know if there is a clip/pin to remove or is it a twisty job/pull off affair. Want to replace the gearknob but hopefully reuse the gaiter
If the knob is not the screw on variety then they normally just tug off, sometimes inserting a feeler gauge up each side of the stick helps to release the clips that hold it on
thanks jj4091 ...... will give it a go..... dont fancy being fleeced by the dealer ... should be straightforward enough
go to a dealer, ask for a repalce ment one, see does it screw in, then "change your mind"
Cheapskate :D :D Good idea though.
On the 306 I had, the gear stick has splines at the top and is a square shape. It literally pulls off, but takes some force! I had one knee on each front seat and pulled it up and twisted it.. Maybe it's the same?
