    Dismiss Notice
Changing diverter valve/O rings: help needed
Discussion in 'Plumbing and Central Heating' started by Dazza001, 3 Jan 2006.
  1. Dazza001
    Dazza001
    22 Dec 2005
    23
    Thanks Received:
    London
    Country:
    Looking to change O rings/diverter valve on my Potterton Performa 24 - anyone got a link to info on how best to do this (I haven't done it before, so would appreciate a step-by-step)? Also, best places to get the parts from? Thanks.
  2. Sponsored Links
  3. caterhamplumbing
    caterhamplumbing
    14 Dec 2005
    34
    Thanks Received:
    Surrey
    Country:
    A Wolsley parts center are quite good. If you are close to Croydon then Curzons or Shoreheat are a god bet.
    Tried your MI for the replacement of the O-Rings
  4. Softus
    Softus
    21 Oct 2004
    19,558
    Thanks Received:
    12
    Country:
    What is the symptom of the problem you're attempting to solve?
  5. Dazza001
    Dazza001
    22 Dec 2005
    23
    Thanks Received:
    London
    Country:
    It's a high-pitched screeching noise that often comes on when the CH is running and a hot tap is then turned on. Turning off the CH for a while is the only way to stop it.
    I posted a week or two back regarding trying some X200 in the boiler, but someone reckoned a faulty diverter valve was more likely...
  6. Softus
    Softus
    21 Oct 2004
    19,558
    Thanks Received:
    12
    Country:
    If you use this link you'll be able to see the service manual. I should point out (a) that you need to be competent, in the eyes of the law, in order to undertake what you're planning to do, and (b) I'm not advocating that you do the work.
    Rather than create a new topic, it would have been clearer if you'd continued the original one, because, well, because it's the same problem.
  7. ChrisR
    ChrisR
    24 Jul 2003
    24,292
    Thanks Received:
    1,399
    London
    Country:
    Do a search on words like "screeching" - various things (washers etc) can do it. I doubt it's inside the DV itself.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
