It is always suggested that when blocking up a fireplace, a vent should be put in to prevent condensation and damp.
I have a 1970s brick-built house with two chimneys going up the middle, which I no longer use. If I block off the fireplace AND cap the chimney, does it still need ventilation?
2nd point: the pots are short clay pipes about 12inches in diameter. To cap them off I thought of cutting a bit of ply, putting a bit of wire through the middle and dropping it a couple of inches down the pot with the wire tied to a small bar across. then filling the top up with cement, leaving a domed top. Is there a better way to cap off the chimneys?
