Hello, new member here although I have been browsing the forums for some time.
My bathroom is in desperate need of an overhaul - it is basically the original 1960s suite, in a tiny room, with the only addition being a Triton electric shower which we don't use as it produces about as much water as a gnat with a kidney stone.
We have an electric water heater (immersion tank, Economy 7 so heats up overnight and has a boost switch for extra heating during the day if needed) which is in the airing cupboard in a bedroom along the hallway from the bathroom, and a cold water tank in the loft above the bathroom.
Am I correct in thinking this set-up means we could install a power shower fairly easily?
And if so, what are the pros and cons of a shower with a built-in pump versus one with a separate pump?
If we went with a separate pump, would it need to be fitted in the airing cupboard next to the hot water tank? Are they noisy in operation, bearing in mind this is in our bedroom?
Any advice or links to relevant sites would be appreciated!
