No it wouldn't be a good idea unless you clean off the chrome where the fitting is going or the water pressure will push it off and cause a bit of a panic.
Chrome Plated Copper with Pushfit fittings........ DONT MIX
I have seen one blow off in a loft which then brought down two ceilings and caused a flood of Rod Stewart impersonators giving their rendition of 'We are Sailing'!!!
Speedfit fittings can be connected onto chromium plated copper pipe if the chromium plating is completely removed to the full depth of the fitting. To ensure maximum grip, the fitting of a collet clip is recommended.
It is not possible to connect Speedfit fittings to stainless steel pipe.
