Circular TCT Blade question?
7 Feb 2006
I am using an Erbauer 2000W 255mm sliding mitre saw to cut old timber for my wood burning stove. I have got into a routine and it works very well. The only problem is that the saw blade can lose teeth when hitting a nail (which I try to avoid but sometimes can't spot them all). I bought the cheapest replacement blade from Screwfix - a make called Titan. I wondered if a more expensive branded make would last longer? Any views on quality TCT blades vs. cheap ones?
get a good blade then you can have new teeth fitted when you have it sharpened
Thanks. Sorry to be ignorant but where would I go to have new teeth fitted? (no wisecracks re the dentist please!)
in my humble opinion just buy 3 blades
1 quality for joinery only
2 cheap blades for you burner no point spending any money on a blade that could be damaged after a few days
Dewalt do 'construction' blades which are very tolerant of hitting nails. If you go a little slower even a normal blade should eat through a nail without much fuss.
The dewalt blades are quite good as they have more metal behind the blade to support the tooth but I don't think they do them in the right profile for a sliding saw only positive rake which can snatch.
Have a look at a replacement blade for the Evolution Rage saws they cut metal as well but do run a bit slower.
J
J
They do negative rake, but seemingly the only size they don't offer that in is 250mm. :/
J
Freud Ultimate blades (previously known as Freud Ultimax) will do this, and are available in 250mm. Easiest way to tell them apart is that they're gold in colour.
J
Thanks for that - I think I will go for a Freud gold blade next time. They are 250mm and my saw requires 255mm. Can I use 250mm in my saw?
It took me a while to get round to buying a Freud gold blade but now it is fitted I have one word - awesome! Cheapest I could find was at Kirby & Wells. Thanks to all for recommendations.
