Cistern Overflow Pipe
23 Apr 2003
Hi
I've just replaced the syphon in my cistern with a 'flapper' alternative (which incorporates an internal overflow) therefore my old bottom fed overflow pipe is no longer needed.
If I remove the old overflow what can I use to plug the hole in the bottom of the cistern that's left behind ?
Any ideas would most appreciated :)
Best regards
Ask your plumbers merchants if they do such a blanking disc for a cistern.
Never heard of one to be honest and may cause you more trouble with it leaking than its worth.
Leave well alone as it is not causing you a problem.
Thanks for the advice Bahco, I think I'll just do that :)
Best regards
Wouldn't that be the same thing as a sink/basin blanking disc?
It may be easier to leave the standpipe inside the cistern, and plug the top of it.
I tried one of those but the thread was too slightly short :(
I thought of that but couldn't find anything suitable to plug it with :(
Best regards
email me your address and i will post you the real plug free of charge and its only a 5min job :D
