Guys,
Wonder if you might be able to offer me some advice?
I had a leaking valve on a radiator connected to the pipework leading to my hot water cylinder. The radiator is situated in the attic and is the highest radiator in all the system.
I drained down the system enough (or so I thought) to replace the valve. During the draining process I heard a gurgling noise from the kitchen radiator so assumed that the system was more then drained below the attic level.
As I removed the valve there was still plenty of water in the radiator which I manually drained. I replaced the valve and refilled the system.
After bleeding the radiators I switched the boiler on to test. I have found that the attic radiator and the cylinder flow and return pipework heat up as it should, however at first I had no heat to any of the other radiators.
I left it over night and tried today. I have found that most are now warming however a couple don't warm up at all. Furthermore I have water pouring out of the overflow from the header tank (when the boiler is on). I'm assuming that there may be a blockage, but am unsure as how to deal with the overflow and cold radiator.
If it helps the system has no pump, or room stat, it does have a programmer allowing the choice of either hot water, heating or both. It is an old Thorn floor standing boiler. I'm assuming that this somehow works on gravity.
Any advice would be greatly appreciated.
Yours
Johnny
Yours
Johnny
