Cold Tank to Hot Water Cylinder
25 Mar 2006
Essex
Could anyone advise the pipework size for the feed from cold water tank in loft to the direct vented hot water cylinder in airing cupboard, 22mm or 28mm.
19 Jul 2007
depends on what size pump you use and also your connection onto cylinder!!
25 Aug 2003
Surrey
even with a big pump 15mm would be **** poor
anyhow you will be pumping from the cylinder not the CWS so the bigger the better to the cylinder as this will be gravity
mind you I have had a few so I could be taliking *******s so to all the other boyos feel free to rip the urine
25 Mar 2006
Essex
Most likely 2-2.5 bar pump, have not got cylinder yet, so not sure about connection sizes!
