Bit of a back story; I am planning an extension to my property and adding in a couple of showers. Currently have a combi boiler; and the usual story of not being able to open a tap while someone is in the shower due to pressure. I want to be able to run 2 showers at the same time without losing pressure.
I have had a couple of plumbers out to quote for an unvented tank and new boiler however they have both mentioned my mains pressure is not that great. (from what the plumber said it is a "3/4" black pipe in to the ho)
Plumber number 1: suggested to upgrade the mains supply to the house to a 25mm and he will upgrade the 15mm pipe to my currently boiler to a 22mm pipe. Boilber will stay in the same location
Plumber number 2: Unvented system with boiler and cold water accumulator tank (Pressurised). His opinion is that if we upgrade the mains to the house the pressure isnt going to increase that much. Boiler and 2 tanks to be moved to the garage.
I really do not want to put a noisy pump in; so these are my 2 options. Does anyone have any opinions on this? what might be the better option(likely to work best)? Is it worth me digging my half my drive to run a new 25mm pipe?
Side note: I have 2 feeds coming into the house (1 to the downstairs cloak room and the other in the kitchen which supplies the rest of the house). The only thing I dont know if these are split along the pipe (T'd off) or 2 separate pipes have been run from the main road.
Pressure on the outside tap was about 2.2 bar and inside tap was about 16 litres per minute
Sorry for the long essay. Just a bit confused as I know nothing about plumbing.
