- Joined
- 2 Oct 2003
- Messages
- 2
- Reaction score
- 1
- Country
Hello All,
I have a 10 year old Combi Boiler that was having problems with pressure build up and a leaking pressure over flow pipe. This went on for some time but as the central heating has not been on for a while it had not been a major problem. Recently (after turning the central heating on and blowing the safety valve) we finally found that the cold water feed for the pressure top up inlet was leaking! This has now been disconnected and the pressure now sits at 1 bar when cold, excellent I thought!
When I now turn on the heating the pressure slowly rises but it does not stop at 2 bar or 2.5 bar which I would expect (hope), it keeps going, when it gets to about 3.5 I loose my bottle and shut it down again.
All the radiators start to get warm and they have been bled, any ideas what the problem could be? As I said, the pressure is now constant when the heating is off but it rises and keeps rising when the heating is on and I can't risk blowing the safety valve again as I have to get a "boiler man" each time to reset/replace the valve and we loose all hot water (which the wife holds me solely responsible for).
