Can anyone give me some pointers on the following problem. I am replacing the radiator in my bathroom and through the course of taking the old one off the wall etc I have found one of the pipe elbows under the floor is leaking so I have no easy way of swapping the radiator over using the old connections and avoiding draining down the system.
I have a Gloworm Swiftflow 80 and I am going to have to drain it down to fix the leak and fit the new pipes, rad etc.
How do I do this? and more importantly how do I re-fill the system once it is all repaired without shelling out for a plumber.
I am pretty sure I just turn the boiler off and drain the rads using the draincock on the downstairs radiator, work on the pipes upstairs and then refill the system using the filling loop to about 1 bar also bleeding the air out the rads as well.
Is there anything else I need to consider when refilling/restarting the boiler etc?
