Combining basin and bath waste
H
HiZ
I would like to join the waste from a basin to the waste under the bath. What would stop the basin waste from flowing into the bath? I will make sure the waste has a good slope by using a shallow type trap for the bath. Do i need to run the basin waste as far as possible from the bath drain and join them just before connecting to the large soil pipe?
Any rules or suggestions?
Before I trashed my bathroom the basin was in a diffrent location and had its own waste into the soil pipe a good 18" above the point where the bath enters it. I've capped off the 'old' basin connection.
bad idea to combine wastes
bugger when you have a blocked bath and sink, need four hands to hold overflows and plugs to plunge the devil
try and keep em seperate
Nige F said:
Combine them and use hep V O waste valves ;)
Hey they look good.
So fit this straigh after the bath U bend to stop the sink back flowing into the bath.
I will then combine the pipes futher down stream.
Or am i using this instead of a bath trap?
Cheers
instead of standard traps, they prevent (as theres no water held in them) from suffering from induced syphonage (gurgurling plug holes).
