common problem?
7 Dec 2008
Kent
I'm replacing my useless and unreliable RF room stat with a wired one. I know which 2 terminals are call & satisfied in the wiring center but do I simply connect the COMMON to the live terminal in the wiring center?
The "digistat" simply says in the manual
1 - COMMON
2 - ON
3 - OFF
Thanks for any help.
J
This is the wiring center:
In the wiring centre
2 is a neutral
4 is the switched live from the prog going to the common on the room stat
5 is the switched live from the room stat to the mid pos valve.
R/S W/C
2 > 4
3 > 5
depending on the room stat you may also need to link up the neutral wire
Thanks for your reply but I'm a little confused by that?
The room stat is a battery powered digistat with the instructions shown in my 1st post. Where exactly do I wire the ON , OFF & Common wires into the wiring centre?
thanks again :)
2 is a neutral
R/S W/C
2 > 4
3 > 5
I've connected 2 > 4 & 3 > 5 as you said but where do I connect the COMMON to the W/C? The room stat isn't operating the heating with just these two wires connected.
thanks
J
Sorry I got the terminals wrong as I was doing it from memory!!
You dont need the neutral wire by the looks of it!!
Digistat > Wiring Centre
1 > 4
2 > 5
1 > 4
2 > 5
That's the cookie!! thanks
I now have it wired as :-
COMMON to terminal 4
ON to terminal 5
OFF is not connected
this seems to be working fine now, thanks for all your help.
J
