Compact radiator - same as 'roll' top convector?
24 Jul 2006
I need to replace a radiator, I have a combi boiler, and I beleive it's what's called a 'pressurised' system?
The rad I am replacing is what I call a standard rad, I think it's referred to as a 'roll top' convector - the size is 1200 x 620.
My local B&Q only sells compact radiators, they have a grill on the top, and what looks like inlets and outlets on the sides at the tops...I'm guessing that's just for bleeding?
I have radiator covers so I'm not worried about them looking the same so is it OK for me to buy a compact radiator and fit it in my pressureized system? Will I notice any difference?
Out of interest, what are the two 'connectors' at the top for?
In case I haven't used the right technology, this is what I'm referring to:
The top picture is what I have, the second picture is what I want to replace it with.
http://www.plumbingpages.com/featurepages/Design.cfm
Thanks in advance, and please excuse my lack of knowledge.
Mark, London, UK
The rads have tappings at top and bottom so that they can be used with different configurations.
There are packs with the rad with a blank plug and a plug with bleed screw supplied.
If you are fitting one of these inside a cover then first remove the sides and top grills to improve the heat output.
Dont forget to switch off boiler and repressurise afterwards.
Tony
Thanks Tony. Can I assume the threads of the nut on compact radiators will be the same as the thread on the valves fixed to my pipe that used to mate to the roll top?
If I buy a 1200mm compact to replace a 1200mm roll top will the pipes be in the correct place...i.e are they the same configuration?
Thanks in advance, simple stuff to you guys, a whole new world for a lot of us...you are providing a great service for the DIY enthusiast.
Regards, Mark
The threads wil be the same, and with a little bit of luck, and care, you'll be able to position the new rad so it fits the old pipes. If it's slightly shorter, you can get rad valve extenders.
"""Thanks in advance, simple stuff to you guys, a whole new world for a lot of us...you are providing a great service for the DIY enthusiast."""
Nice to find someone who values our help. That makes a nice change!
Last one said that "I had been unhelpful as always".
Tony
