I am in the process of completely refitting the kitchen and would like some advice regarding the electrics. Forstly, let me say that I am getting in an electrician and he has already given us the quote to connect up and test etc. However, I am putting all the boxes in the walls and putting the cables in ready to be connected up.
I would like some advice regarding the low voltage undercabinet lighting I am planning to put under the wall cabinets. These will be 12v units and I am planning to have the transformers sitting on top of the wall cabinets. Therefore I will need a 13A socket above the wall cabinets to plug the transformers into and then I was planning to have an isolating switch at normal socket height above the countertop to switch the power to the socket to turn on the power to the transformers and hence turn the lights on.
Firstly, does this sound ok and, if so, what sort of switch would I need to act as the light switch. Would this switch here be what is needed.
I do have a couple of other questions but let's deal with this one first.
Many thanks
Russell
Many thanks
Russell
