concrete fence panels brick/rock stone finish
2 Oct 2004
Concrete fence panels damaged posts ok replace panels
1080mm between posts height 1600mm aprox
or brick/block work between posts ?
TIA
TIA
what are you actually asking here :?:
he wants to know wether to replace his fence which is made of gravel boards ( or something similar ) with the same or put brickwork in instead..
if you go the brick route you will need to lay a foundation and mortar between the bricks so you might as well take the posts out and do it all as a wall.. ..
