Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Is there a building regs requirement to insulate a concrete floor in any way? Builder put down a waterproof membrane but thats about it, is that enough?
I mean I had to ask what kind of building the floor was poured for. Now we know its an extension we can ask:
1) Is there any insulation under the slab?
2) Have you asked your builder?
3) Is the floor finish to be boards or a screed?
4) What depth have you between the top of the concrete and the finished floor level in the existing building?
5) Are you doing this to building regs?
6) What do the drawings say?
Typically you'd expect approx. 90mm of rigid insulation such as Kingspan or Celotex for an extension to a dwelling depending on the perimeter and area of the extension.
