hi , can you please tell me what mix to use i am laying a hard standing 5" thick for a stable to go on and am not sure what ratio ballast Vs cement , please help ,,,thanks
I would use 1 cement, 2 sand and 6 gravel for this, its what is called a C15P mix, and is usually used in foundations, so ample strong enough for what you want
its hard enough to walk on after 24hrs, but is far to "green" to fix to or do anything else. if you could leave it over a weekend then it wont scuff so badly if you need to work on it.
