Confused by loss of water
26 Apr 2012
Hi all, I'm no expert in central heating so could do with a little advice, I have recently removed a radiator and drained the system and refilled with water without inhibitor for now, I will add later as I will have to drain the system again.
I can bleed the system successfully and the pressure is at about 2.5 bar, but As soon as I run the heating system I am getting water venting by what I guess is a relief valve, it's venting to a pipe that goes outside the house,, the relief alve the other side of the wall seems to be spring loaded with no adjustment, so is it doing its job, is it faulty,? Why is it venting the system, in the morning the system is only at .5 bar if that
2.5 bar is too high but it sounds like your expansion vessel has lost it's charge pressure or failed. Judging by your description you know nothing about boilers so I'd get a professional in to look at it.
Hi, I have looked outside the prv is constantly dripping, and the path is soaked, pressure is at 1 bar and its a constant drip, what I ou think, faulty prv
Alsoit's dripping with he heating off as well as on
Sealed system PRVs can't be adjusted, it could be dangerous to be able to do so. +1 on swbjackson's post. Once these valves lift, it is quite common for them not to seat properly again, causing system pressure loss.
Cheers, so what's the answer? No valve, if so time for a plumber
Time for a heating engineer is the answer. Get the PRV replaced, check expansion vessel charge too, whilst the boiler is drained. Any decent RGI will know straight away what to check as soon as you tell them the symptoms.
