I'm building a conservatory which needs a 13.7 metre long foundation trench. It's not going to be under building control, but I want to do a proper job so I'm expecting foundations to be around 650mm deep based on my initial dig/examination. The cavity wall will be 255 wide, plus 150mm either side, giving a foundation width of 555.
If I was to build up from 15cm below ground level, I'd need 4 cubic metres of concrete. This seems way too much to mix in my belle 140, but ready/mini mix at ~£120 a cube seems like a lot too, so now I'm considering something like a 200mm foundation and then block work up to ground level. The obvious dilemma is that I spent a day or two laying the blocks rather than buying the readymix.
Any thoughts? Am I under/over estimating the work/money involved anywhere?
Gary
Gary
