I am building a conservatory (approx. 3m x 3m) with a 600mm cavity dwarf wall. I will be running power cables along the cavity. The windows are 24mm double glazing and the roof is triple wall polycarbonate.
Is there any benefit to using insulation between the two walls since I assume most of the heat will be lost through the roof? I have not put any insulation in the concrete floor. If insulation is needed what type would you recommend and roughly how much would it cost? I have a tight budget.
