I have been asked by a friend of mine to finish off a re-wire on a flat that he has been renting out, i have a good understanding of electrics and i have also my c&g 236 pt 1 under my belt but never had the time to get my part 2, any way the problem i have come across is at the consumer unit, all the new circuits are in place and the cu is a wylex 10 way split board. The problem i am having is with the lighting circuits. There are 2x 1.5 mm t&e 1x1.5mm t&e (which has two red conductors and earth) and 1 single 1.5mm red conductor and 1single 1.5mm black conductor.
Would all these be separate lighting circuits? The reason i ask is because the mcbs were already in place at the cu and there is only one 6a mcb 4x16a mcbs and 3x 32a mcbs.
Ihave sorted the power circuits out and they are all on the rcd side of the board, but cant work out as to why there is only 1 6a mcb in situ?
any ideas fellas?
thanks
any ideas fellas?
thanks
