Cooker hood tripping RCD?
6 Jan 2007
Manchester
I was called to a job yesterday, where the new cooker hood is intermittently tripping the RCD when the hood is turned off. The hood is connected via a 3 amp FCU to the RCD protected downstairs Ring.
Checked the circuit at fault, and found no probs, a well fitted and modern installation. Meggered it, as I would have expected the fault to be caused by poor insulation resistance, typical N-E fault. This isn't the case, all tests fine.
Despite the hood being double insulated, has anyone experienced any leakage, which may indiacte the hood to be the cause of this fault? I can only suggest he replaces the hood, p.s only trips every few weeks, and when the hood has been working for a good length of time and is turned off -trip!
any help would be appreciated.
Ant
Might be condensation from cooking steam.
How do you know the cooker hood is tripping the RCD?
John - I'm not mocking your idea, but cannot see where the leakage would be on a DI item?
Didn't notice DI :oops:
I'm thinking moisture, kitchen, cooking, steam, condensation.
Might not be in the hood, though. Could be FCU or flex outlet or whatever.
OK Smartypants - just 'cos you're a lateral thinker...
My turn for a " :oops: "....
