While repairing a friend's leaky radiator, I found that the copper final
connections to the radiators were attached to plastic pipe behind the
plasterboard, but with no connector apparent. The microbore appeared to
have been shoved up the 10mm plastic. The ends of the plastic are not
cleanly cut (looks like the plumber chewed through the pipe).
While the connections were not related to the leak (yet), is the method:
a) a common way of doing things?
b) a short-cut too far?
c) both of the above?
PS. The plastic was white - couldn't see enough to see a brand name.
