Copper Tube Insulation
23 Jun 2017
Hello. I was referred here by a mate who reckons it's a good source of info.
I am going to be replacing some of my copper water and central heating pipework in my bungalow loft soon as I've just moved in and none of the pipe is insulated or fixed and some of it has horribly bodged connections on it.
I've bought some armaflex 25mm insulation for the pipes but I wondered how you pro's fit the pipes once the insulation is on as the normal hinged or push-fit clips don't allow 25mm clearance for the pipe insulation.
I was going to buy some talon clips because they do spacers for them but after seeing the specs for these, they only give another 13mm extra and my insulation is 25mm.
If anybody could give me some pointers I would appreciate it.
Thank you.
A.
Thanks for that. as usual, I didn't see that they could be stacked ! Problem solved then.
Much appreciated.
Use Munson rings with male backplates , if the insulation requires more clearance then use female backplates and studding (threaded rod).
Thank you.
A.
Eh, use two spacers??!! Is it just me?
I didn't notice on the website description on screwfix that they could be stacked.............I put it down to my age - hehe.
Ah, non of us are getting any younger mate. You have fun pulling yer pipe.
