    Dismiss Notice
Correct Length of immersion heater on Hotwater Cyclinder
Discussion in 'Plumbing and Central Heating' started by nickwhittaker, 30 May 2005.
  1. nickwhittaker
    nickwhittaker
    29 May 2005
    9
    Thanks Received:
    Country:
    I am about to buy a new standard hot water cyclinder (indirect open vent) which is 1050 mm high. The immersion heater will only be for occasinal use. I see there are lots of different lenghts at the same 3 kw power. Would a 27 inch (685 mm) heater be OK?
  2. doitall
    doitall
    8 Jan 2005
    19,003
    Thanks Received:
    1,538
    Bath
    Country:
    27" is fine.
    :LOL: :oops: :LOL:
  3. Sponsored Links
  4. kevplumb
    kevplumb
    18 May 2004
    23,712
    Thanks Received:
    925
    depends where i get sent
    Country:
    you wish ;)
    yeah it will do the job
  5. CopperCylinderMan
    CopperCylinderMan
    1 May 2005
    31
    Thanks Received:
    Fife
    Country:
    as they say, 27" is fine.
    If an immersion is side entry, maximum immersed length is 50mm less than the diameter of the cylinder.
    If top entry then max immersed length is 200mm less than the height of the cylinder.
    CCM
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
