Hi All, getting ever closer to completion of my garage conversion
With regards to building regs, when I get this signed off is the inspector going to check up on the size of the room and the size of the radiator I have installed?
All other rads in the house a single skin, not double type. What would you recommend installing below this window, should it run the full width of the window or could it be taller but more narrow? I understand under window is best for hot air to circulate within the room.
Window about 220cm in width
ta
KS
View media item 6149
ta
KS
