couple of things...
2 Sep 2008
South Glamorgan
Hi all I'm hoping someone can advise me....
I had a chemical dpc injected along the outside wall of my end terrace house in august. The walls however did not have the plaster removed as I was told it wasn't necessary (by Rentokil who did the work). The walls are still wet - especially where they used the tool to probe into the wall to check the damp levels (there are very obvious circles around the areas maybe 4cm in diameter.)
Please can someone tell me what to do as this is driving me to distraction!!
Secondly, I was about to hang a new blind in my bedroom window this afternoon when i noticed a vertical crack about and inch and a half in from the window which runs the whole height of the window. The crack is approx 3mm in diameter and the plaster has started to come away from the brick behind it.
This is my first house and I feel I was well and truly shafted, as there are numerous other things the previous owners covered up in order to sell. If someone can give me some advice Id be really grateful.
