Crack upstairs interior wall
10 May 2010
Sussex
I wonder if anyone can provide some advice..... I have noticed a crack that has appeared on our bedroom wall, the wall is an interior wall with the hallway being on the other side. The crack is in the centre of the room running from the floor straight up and is about 8 inches in length and is definately a hairline crack.
We haven't carried out any decorating in this room, the house was built around 1860 so the walls are lath and plaster as opposed to plasterboard.
If this was where we had carried out some decorating or there was a leak I could understand the reason for the crack. Would be grateful for any thoughts.
Many Thanks
My advice would be to fill it and ignore it. It doesn't sound like much of a problem really.
But if it comes back or gets worse - post a photo.
To get light cracking in a lath and plaster wall/ceiling is very common. The 8"crack you have in your wall, is "trivial" and you shouldn't worry about it at all.
On the other hand,, to find a lath and plaster wall/ceiling "without" cracks in them would be a rarity.
Scrape it out (widen it) brush all dust from within it, and then fill. Should solve the problem.
I have found (does not always work) that if you drill a hole at either end of the crack it stops it spreading.
They used to do this with stress cracks on aircraft (not anymore though) and it also often worked. But because it did not always work, they stopped doing it on aircraft, but they still do it on ground based constructions. :lol:
