Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Does anyone know where I can get M6 10mm long cross dowels I have been looking all over the net but 12mm is the shortest I can find, which I already have and are too long
Will 6mm x 10mm units work OK in 10mm board. You only have a maximum of 2mm wall thickness in the wood, assuming a 6mm bolt hole. You might well find the board edges break out when you tighten the bolts.
