Crypto mining electrics
Discussion in 'Electrics UK' started by miner2004, 25 Sep 2021.
  1. miner2004
    miner2004
    25 Sep 2021
    6
    Thanks Received:
    Country:
    Hi all,
    Over the past year ive got into mining crypto. Ive had a 10mm cable run from a 40amp fuse to my workshop about 15m away from the main board. The cable is run along the wall, not in insulation/trunking etc.
    I believe i am pulling close to 40 amps now, but the cable and fuse are hot. With my IR thermometer the 40amp fuse reads at 59 degrees and the cable at 37. My electrician has been out again and says its fine, the fuse will trip if it gets much warmer though, but thats the point to protect the circuit etc. It just im pulling so much power.
    Does this sound ok to other electricians or would anyone have any other recommendations?
    Thanks.
  2. Sponsored Links
  3. conny
    conny
    30 Jun 2008
    14,285
    Thanks Received:
    837
    Suffolk
    Country:
    You're going to need to strike lucky with the crypto to pay your electricity bill at that rate!
  4. RandomGrinch
    RandomGrinch
    15 Jun 2021
    1,589
    Thanks Received:
    347
    Wales
    Country:
    Sorry,
    Not helpful to your situation, but is your setup running 24/7?
    9.2kW per hour,
    80.5MW per year
    At average 14p per kWh
    £11300 per annum bill, plus normal household electricity?
    • Thanks Thanks x 1
  5. flameport
    flameport
    10 Mar 2007
    10,110
    Thanks Received:
    2,039
    Poole, Dorset
    Country:
    Cables and other current carrying items heat up when in use. It's inevitable and caused by the resistance of the cables.
    Standard PVC insulated cables are rated to 70C conductor temperature at full load. The outer covering will be slightly cooler.
    High continuous loads need to be notified to the electricity network operator, as the networks were not designed for such things.
    As above - this will be costing you a fortune in electricity use.
  6. miner2004
    miner2004
    25 Sep 2021
    6
    Thanks Received:
    Country:
    Yes electrcity is alot, im not sure how viable it will be with everyone going under and the rates going up. At the moment in time its still profitable mind. We do have solar panels but i dont think it touches the sides lol
    Do those temps sound ok then flame? I knew it could get to 70 but wasent sure how insulated the cable would be and effect the outer temps.
  7. Mr Chibs
    Mr Chibs
    28 Jul 2015
    1,098
    Thanks Received:
    182
    Country:
    My supplier has just issued me with new intended electricity kw rates... from .16p to .23p, so that crypto bill may be higher:eek:
    • Like Like x 1
  8. miner2004
    miner2004
    25 Sep 2021
    6
    Thanks Received:
    Country:
    *Grabs another beer and cries*
    • Like Like x 2
  9. Mr Chibs
    Mr Chibs
    28 Jul 2015
    1,098
    Thanks Received:
    182
    Country:
    Dare I ask what hardware is actually using all that leccy?
    I had a coronary when my new coffee machine uses 2000 watts :D
  10. Sponsored Links
  11. JohnW2
    JohnW2
    28 Jan 2011
    49,186
    Thanks Received:
    3,247
    Buckinghamshire
    Country:
    I must say that I was wondering the same, given that an 'average PC' probably consumes an average of under 1A.
    Kind Regards, John
  12. miner2004
    miner2004
    25 Sep 2021
    6
    Thanks Received:
    Country:
    8, what is basically pcs
    a few fans
    routers etc
    Main usage is the 88 graphics cards
  13. RandomGrinch
    RandomGrinch
    15 Jun 2021
    1,589
    Thanks Received:
    347
    Wales
    Country:
    You should be glad it's not gas powered!
    That would be a fortune at current prices! :LOL:
  14. JohnW2
    JohnW2
    28 Jan 2011
    49,186
    Thanks Received:
    3,247
    Buckinghamshire
    Country:
    Good grief :) What on earth .... ??
    Kind Regards, John
  15. Colin Brenton
    Colin Brenton
    1 Mar 2008
    169
    Thanks Received:
    33
    Country:
    And what about the future of the planet?
    Or do you consider that that is just "someone else's problem"?
    FGS!!!!!
    • Thanks Thanks x 1
    • Like Like x 1
  16. mikeyd
    mikeyd
    17 Jul 2007
    794
    Thanks Received:
    76
    Country:
    I wondered where BAS had gone.
  17. Alec_t
    Alec_t
    18 Mar 2017
    782
    Thanks Received:
    137
    Wales
    Country:
    Excuse my ignorance, but why does crypto-mining require more than one graphic card, yet alone multiple high-powered graphics cards?
    With all that power you should be able to run a district heating scheme :D.
Loading...
Share This Page
