Hello,
I want to route 22mm flow/return CH plastic pipes to rads and I want to drill holes through the joists to feed the pipes through instead of cutting slots on the top with a saw.
However, the joists are too close together to get a drill in between to cut a hole that is at right angles.
Is there a specific tool available that does this, or is it the normal practice to cuts slots in the top of the joists to accomodate CH pipes ?
Thanks in advance
Thanks in advance
