Daikin air con unit
18 Dec 2011
Yorkshire
Hi,we have just moved and our Daikin wall mounted air con unit trips the main breaker when it switches to heat, any suggestions please
It is the compressor solenoid, probably the unit has been leaking gas and therefore is frosting up on normal setting, this is melting on swtichover to heat. Water from this is then shorting out the solenoid.
You need to mend the leak, which may not be economical. Also the compressor may have failed
