I'm trying to tile with 40cm porcelain tiles. Using a new Screwfix snap cutter but the little tungsten carbide wheel seems to have a bit of play such that it pulls as much as 3 mm to either side as you score. There's also some flex in the whole structure of the cutter. In other words, after I line my tile up in the cutter, the score starts where I wanted it but by the time I reach the other end of the tile, it isn't where it was supposed to be. When you've got 2mm grout lines, a 3mm error is completely unacceptable.
Do I need a better quality cutter? If so, what's a good tool and where to buy? How much should I expect to spend?
Also tried hiring a wet saw. It tended to break tiles, especially when you got to the last 1-2 cm of cut! And it was extremely difficult to stay on a line. It seemed the width of the cut was exactly equal to the width of the blade giving you absolutely no room to "steer" as you progressed through the cut. (couldn't use the fence because most cuts were not exactly parallel to the sides of the tile). I ended up doing multiple passes gradually "shaving" the tiles gradually down to the line I wanted to cut. Very tedious and the final line was a bit wobbly.
Did I have a bad saw or what? I understand you can buy wet saws for as much as I paid to hire one. Is there a good product out there? Advice please?
