Dimmer for 2 -way lighting
8 Mar 2006
West Midlands
I have a 2-way lighting circuit controlling to sets of G9 lights and would like to put a dimmer in circuit. - does it matter which switch is converted to a dimmer type or does it have to be the switch with the power feed to it i.e. the one with the 3-core and 2-core. The two sets of lights are 120w rated each - what should the dimmer rating be?
Doesn't matter which end, but you should note that you can only have one dimmer, I am unsure if the lights you have are halogen or not (not familiar with G9) but the rule of thumb for halogen lights is to double the load and use that to size the dimmer
G9 are Halogen...Am I right in thinking that my load would be 240w (120 + 120)...so the rating required would have to be 500w?
No.
Unless specifically rated for halogen lamps, 400W minimum.
