Dimming Halogen - 2 problems
23 Apr 2008
West Midlands
I have two problems with dimming halogen which confuse me more the more I read.
Problem 1 – Dimming 9 x GU10 bulbs
I have 9 x 50w GU10 halogen spotlights in the kitchen which I want to dim (lamps are dimmable), I assumed I would need a 450w dimmer but from what I have read I need a higher rated one – is that still the case or have manufacturers improved in recent years?
Problem 2 – Installing a low volt light to an existing dimmer
I have a Volex 4 gang 1 way dimmer and want to change one of the ceiling lights connected to it.
The dimmer is Digitrac, 40-250w, 220-240v, 50hz.
The light has 12 x G4 max 20w lamps, 230v and is dimmable, but the light shop say I need a special dimmer or risk blowing the transformer - is that the case, or is the dimmer I have fine? Assuming the dimmer is unacceptable is there another way around this, could I change the transformer for example?
