dishwasher
26 Apr 2012
Hull
I have a dishwasher on a combi system, the dish washer wont drain but it is connected to the same waste trap as the washing machine which does drain fine, what could be wrong ?? :?
Disconnect the drain hose and let it fall into a bucket....if the machine drains now, then its an obstruction in the waste trap under the sink.
If it still doesn't drain, then its a pump issue (blocked or not running), filter blockage, kinked hose or similar.
John :)
John :)
its a brand new machine too, give that a try , thanks john
Some undersink machine traps are actually blanks - and you cut the blank end away when you want to start using it......hope its as easy as that!
John :)
