Do I Need A Room Thermostat or TRV's (or Both)?
4 Feb 2005
I recently replaced the old boiler with a Baxi 105e instant combi boiler. At the moment there's no room thermostat fitted and only a newly installed radiator with a TRV.
Is is recommended to install TRV's on all the other radiators in the house?
If I do this should I also fit a room thermostat as well, or is one not really necessary with TRV's fitted?
Without a room thermostat I was expecting the boiler to flame up (be on all the time). But it doesnt. Does the boiler have the ability to regulate the temperature and turn off when the CH temp gets a certain temp. Also like all combi boiler I guess, I have the ability to set the CH temp via a simple dial. Is this doing the same job as room thermostat then?
Is it easy to fit a thermostat if need be to this particular model? Any recommendations? Am I right in thinking the prices of the room thermostats are in the region of 15-25 quid for a decent one?
Any advice would be appreciated.
Taz.
“Never buy a dwarf with learning difficulties – It’s not big and it’s not clever."
All boilers - well, all the ones I've ever seen - have a built in thermostat to stop them from actually boiling the water. If you fit all your radiators with TRVs and leave out the room stat, the boiler will cycle on and off on its internal stat. This isn't good. Put a room stat in the room that takes the longest to warm up and don't fit a TRV to that radiator. (If you already have a TRV, turn it to maximum.)
Well said Felix. Fit a room stat, otherwise when the rads shut down the the water cannot cool the boiler jacket. The dynamic range of the gas jet is not much and it cycles constantly ... Flounder
Thanks for your prompt response felix (u have trouble sleeping as well mate :D )
Bought myself a thermostat and push fit TRV today. Fitted the TRV to the main bedroom. Well chuffed, as first time I fitted a new valve.
Got a cheapo thermostat at 13 quid, Siemens make. Should do the trick. I've got a fancy digi 7 day timer on the boiler, hence the basic thermostat. Will attempt to fit it tomorrow, or should that be today :!: (quick glance at PC clock).
