I am in the middle of some building work. The contractor would, with my permission, like to change the 'sarking' from Marine Ply to sheathing grade ply. The specific areas where they want to change the material are on the roof and sides of the dormer. The build-up of the sides is apparently like this:-
Paint
Built- up render
Stainless steel EML
Vapour barrier (used to keep the cavity clear of snots of render)
50mm timber battens to form a cavity for ventilation
Breather membrane
Sarking
Studwork
Insulation between and over the warm face of the studs
Plasterboard
I am concerned that the sheathing ply is clearly NOT designed for exposure to moisture. Should I allow the change?
Thanks in advance
Paint
Built- up render
Stainless steel EML
Breather membrane
Sarking
Studwork
Plasterboard
Thanks in advance
