Hi, had some sparks round to quote to fit some lamps but neither wanted the job (amazingly!) and second one told me what to do, I'm a plumber so know a little (which can be quite dangerous!!). Could someone see if this all sounds ok?
I've wired 8x50w 240v fire rated downlights (bedrooms above) in my lounge, 4 running off each pendant which I have replaced with 15a terminal strips in choc boxes. Both switch wires go to one 400w dimmer and it's all run in 1.5 T&E. Terminals are big enough for 2 wires on lamps so I have daisy chained them directly to each other.
In my kitchen I have 8x50w 240v fire rated downlights running off a pendant which I have replaced with a specialist downlight box (maintenance free apparently as it will be hidden away). Again all run in 1.5 T&E. Instead of daisy chaining I ran a feed front to back of room and wired 2 lamps on 4 "spurs" coming off this feed.
All connections are 15A terminal strips in choc boxes.
I now have max 1600w of lamps downstairs which equates to approx 7A on the existing wiring (all 1.5 T&E) which should be ok by my calculations?
