DPM on old car port base 5x4m
30 Mar 2012
Monmouthshire
I blocked up the old car port to convert it domestic use. It has a membrane under the conc slab but building control say I also need a dpm over the slab and slightly up each wall: makes sense I suppose, it'll have a plywood floor + engineered wood, on battens.
What type of membrane do I need?
There are a few slightly odd corners, and I will need stud/insulation on inside faces of some of the walls. It would be handy if I could get some membrane down around the outside of the room and joint a centre piece in later to preserve access for a while and prevent membrane damage during works, if some sort of jointing tape was available. How are joints created in DPM, are they rolled or taped joints?
I imagine that running the memrane up the wall in an inside corner would be easy enough to accommodate with a fold or two in the corner, but an external corner would need some sort of tape?
Do I need to protect the membrane with geotextile?
My guess is that the original membrane sat underneath a concrete slab and there is not way to connect it to the walls.
I think that because generally dpm would not be required below a suspended floor.
Standard 1200 gauge plastic dpm is fine. If it is an awkward shape, a liquid dpm is an alternative.
You can join dpm, use a 600 lap mm and use tape. I think ideally it should be folded, but thats easier said than done with thick polythene so I just say a big overlap works.
You can buy tape for it. Or the super sticky gorilla tapes works. Dont use ordinary duct tape
Maybe the void neneath the ply base will be enough to accommodate a folded joint.
I'll leave a meter or so out front of the baseplate, so I can do either.
Liquid Dpm .
Sika Rapid 5 litres for £70 which conveniently doesn't seem to be a 2 pack, so maybe I could just do where the sole plates are going with that and finish the rest of the base later.
Coverage seems to ok with 5 litres providing 2 coats over 20m².
Has anyone ever used it?
