drainage problem on Bosch Classixx 1400
1 Oct 2009
Merseyside
HI i have just purchased a second hand Bosch machine. On trying it out everything seemed fine until water was draining out of machine. Water was overflowing onto floor. On closer inspection i could see at the back of the machine the water was overflowing out of the drainage pipe? Any ideas why this would happen? Do i need a special pipe? I have just used the same one as my last machine i put the pipe inside the drainage tube. Any got any help please.
or is the waste pipe too far down the tube ,should be about 6 inches from the top.
Where's the water coming from, the washing machine upstand or the actual point of entry of your waste pipe into your Washing machine?
hi have tried to pull pipe up but water just overflowing out of pipe. Have cleaned pipe out but still happening have also noticed water gurgling up into sink? This never happened with my old machine, an elderly neighbour tried to fix it for me and when i have got home from work he has taped drainage hose to tape and told me not use the sink if i use washing machine! I dont want to carry on like this and dont know why everything worked ok for my old machine but this one water everywhere?
