Have an old solar heating system and the switch between domestic/solar is the above actuator, its a manual switch and normally when switched it reaches its open/closed limit and stops running, its just recently started to reach where it should stop and is clonking, so much that I have to turn the system off, this happens at both ends of its cycle, ie when I switch to solar or domestic.
Does this mean it has to be replaced, its an expensive item
If I have to replace it can I change it somehow to automatically sense the changeover or would this be a big job?
