Drayton LP241
15 Mar 2011
Leicestershire
Hi many thanks in advance,
I had a power cut over the weekend, since then I have had issues with my hot water not being heated. CH works fine with the thermostat but HW light comes on with no action at the boiler. I can move a switch on a box next to the boiler from auto to manual and it then switches on the boiler for HW? Hope this is enough information. Also what should the settings be on the two boxes next to my boiler they seem to work by pressure one is silver (CH)? with a leaver at the side and the other similar but plastic for the (HW)?.
many thanks
Its probable that the back up battery in the LP241 has failed. It may well come back on after a few hours charging.
I assume the yellow lights up OK?
You dont need to touch the motor valves but can latch them in manual if that brings on the CH/HW as a temporary measure.
Tony
Tony
Thanks AGILE - The power outage was only for 30mins could that still be the problem?
Yes, because they only charge at a very slow rate.
I am not saying that IS the problem, only that it may be.
Tony
