First let me say I am as far from a plumber as it is possible to get...
I've got a dripping mixer tap (dripping from hot water side). I took it apart expecting a washer/jumper type fitting but it has a rotating cylindrical metal plate with two holes in it and two (what look like) rubber grommet/spring things which push against it forcing a seal when the valve is shut. These grommet/spring fittings are worn and I'd like to replace them but I've not got a clue what they are called!
Can anyone help me with the name of them or what this type of valve is called? Are they a common type of tap fitting? They seem a bit half-arsed to me
buckie
buckie
