Dual Sliding Barn Doors
30 May 2013
Lancashire
Hi, we are looking at fitting dual sliding barn doors to separate our dining room and play room / guest bedroom. We also want to have a lock fitted for privacy. Has anyone done this?
I'm a little confused over what handles to use as well, I've seen this privacy set but then what do I do with the other door handle. thanks
It hooks into a receiver plate on the other door. It presumably ships with such a plate.
The vendor's drawing clearly shows the handles being installed back to back on one door. The non-operating side looks to have a ln indicator on it which kets you see if the door is locked or not (and may ir may not allow unlocking from that side using a slotted screwdriver in the event of need, a bit like a toilet indicator set does)
